Zum Hauptinhalt wechseln
Datawind Ubislate 7ci Battery Replacement
Was du brauchst
  1. Datawind Ubislate 7ci Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Datawind Ubislate 7ci Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • Be careful of the device's small wiring when separating the two halves.
  2. Datawind Ubislate 7ci Battery Replacement: Schritt 2, Bild 1 von 3 Datawind Ubislate 7ci Battery Replacement: Schritt 2, Bild 2 von 3 Datawind Ubislate 7ci Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the black tape.
    • Be careful not to remove the tablet camera.
  3. Datawind Ubislate 7ci Battery Replacement: Schritt 3, Bild 1 von 3 Datawind Ubislate 7ci Battery Replacement: Schritt 3, Bild 2 von 3 Datawind Ubislate 7ci Battery Replacement: Schritt 3, Bild 3 von 3
    • Use a soldering iron to remove the battery from both its attachment points.
    • Pry off the battery using an opening tool.
  4. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: Schritt 4, Bild 1 von 2 Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: Schritt 4, Bild 2 von 2
    • Insert your replacement battery in the same spot as the old battery.
    • Tape battery into place.
  5. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: Schritt 5, Bild 1 von 2 Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: Schritt 5, Bild 2 von 2
    • Solder the new battery to the connection points.
    • Press the back cover on firmly until it clicks.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Mekides
40 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G3
3 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
On my 7Ci the battery is SFH-HLKJ-204.
Datawind doesn't sale those pieces.
Where can I find one?
What type is it, voltage and so?
THX!
ylco - Antwort
3.7V, 2200mAh lithium ion. Yiu can get a bigger or smaller one depending on shat you want.
Jessica Parnelli Fawkes - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 9,018
