Zum Hauptinhalt wechseln
Datawind Ubislate 7ci Rear Facing Camera Replacement
Was du brauchst
  1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: Schritt 1, Bild 1 von 1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: Schritt 2, Bild 1 von 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: Schritt 2, Bild 2 von 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.)
  3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: Schritt 3, Bild 1 von 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: Schritt 3, Bild 2 von 2
    • Remove the black tape that is circled.
    • The camera is circled in this picture.
  4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: Schritt 4, Bild 1 von 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: Schritt 4, Bild 2 von 2
    • Carefully remove the camera from its housing.
  5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: Schritt 5, Bild 1 von 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: Schritt 5, Bild 2 von 2
    • Slide the new camera into its housing carefully.
    • it should look like the second picture when you are finished
  6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: Schritt 6, Bild 1 von 1
    • Press the back cover of the tablet on firmly until it clicks
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Mekides
40 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G3
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 291
