Zum Hauptinhalt wechseln
Sony Xperia Z3 Dual Earpiece Speaker Replacement
Was du brauchst
  1. Sony Xperia Z3 Dual Earpiece Speaker Replacement, Earpiece Speaker: Schritt 1, Bild 1 von 1
    • Power off and remove two SIM card trays at first before earpiece speaker replacement.
  2. Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 2, Bild 1 von 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 2, Bild 2 von 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 2, Bild 3 von 3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick.
    • Slide guitar pick to cut the sticker.
  3. Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove back cover.
  4. Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 4, Bild 1 von 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 4, Bild 2 von 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 4, Bild 3 von 3
    • It's easy to remove the battery.
  5. Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 5, Bild 1 von 1
    • Twist off two screws at first.
  6. Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 6, Bild 1 von 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 6, Bild 2 von 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 6, Bild 3 von 3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 7, Bild 1 von 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 7, Bild 2 von 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 7, Bild 3 von 3
    • Release all the connectors connecting with motherboard.
    • Pry motherboard up from left side. It's really hold tightly by some hidden keys, so be careful.
    • Remove motherboard.
  8. Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 8, Bild 1 von 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 8, Bild 2 von 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: Schritt 8, Bild 3 von 3
    • Remove the blocker beside earpiece speaker and you can see the breakout to pry up the speaker.
    • Remove earpiece speaker finally.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Sophia
43.810 Reputation
62 Anleitungen geschrieben
3 Kommentare
Thanks for the guide, it worked very well.
Maybe it's worth mentioning that there's a sticker at the back of the battery and you shouldn't be afraid to just pull the battery out.
Steven Kolenberg - Antwort
Hai. Can you give me the link to buy the earpiece? Tq
Wafi Sams - Antwort
Thanks for the guide, however my ear piece speaker now rattles when i play music at medium levels. I have tried installing additional adhesive to it, but still cracks.
Tony Ho - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 16,196
