Zum Hauptinhalt wechseln
CM Storm QuickFire Rapid Large Keycap Replacement
Was du brauchst
  1. CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: Schritt 1, Bild 1 von 3 CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: Schritt 1, Bild 2 von 3 CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: Schritt 1, Bild 3 von 3
  2. CM Storm QuickFire Rapid Large Keycap Replacement: Schritt 2, Bild 1 von 1
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. CM Storm QuickFire Rapid Large Keycap Replacement: Schritt 3, Bild 1 von 3 CM Storm QuickFire Rapid Large Keycap Replacement: Schritt 3, Bild 2 von 3 CM Storm QuickFire Rapid Large Keycap Replacement: Schritt 3, Bild 3 von 3
    • Install the plastic rings on the new keycap. The overhang needs to be ‘facing forward’ so that when the keycap is placed back on the board, the overhang is furthest away from you. When attaching the new key to the board, the ends of the metal bar on the board will go through these rings.
Abschluss
Cal Poly, Team 6-23, Maness Fall 2014 Mitglied von Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 20
Insgesamt: 5,622
