Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein T-Mobile Huawei Prism U8651T zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. T-Mobile Huawei Prism U8651T Teardown, Remove Back Cover Panel: Schritt 1, Bild 1 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Back Cover Panel: Schritt 1, Bild 2 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Back Cover Panel: Schritt 1, Bild 3 von 3
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T Teardown, Remove Battery: Schritt 2, Bild 1 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Battery: Schritt 2, Bild 2 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Battery: Schritt 2, Bild 3 von 3
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T Teardown, Torx Screws: Schritt 3, Bild 1 von 3 T-Mobile Huawei Prism U8651T Teardown, Torx Screws: Schritt 3, Bild 2 von 3 T-Mobile Huawei Prism U8651T Teardown, Torx Screws: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    T4 Torx Screwdriver
    $5.99
    Kaufen
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T Teardown, Remove Plastic Mid Frame: Schritt 4, Bild 1 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Plastic Mid Frame: Schritt 4, Bild 2 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Plastic Mid Frame: Schritt 4, Bild 3 von 3
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T Teardown, Remove Power and Volume Buttons: Schritt 5, Bild 1 von 2 T-Mobile Huawei Prism U8651T Teardown, Remove Power and Volume Buttons: Schritt 5, Bild 2 von 2
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T Teardown, Remove Power Button Sensor Strip: Schritt 6, Bild 1 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Power Button Sensor Strip: Schritt 6, Bild 2 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Power Button Sensor Strip: Schritt 6, Bild 3 von 3
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T Teardown, Remove Volume Button Sensor Strip: Schritt 7, Bild 1 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Volume Button Sensor Strip: Schritt 7, Bild 2 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Volume Button Sensor Strip: Schritt 7, Bild 3 von 3
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T Teardown, Remove Outer Screen Connector: Schritt 8, Bild 1 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Outer Screen Connector: Schritt 8, Bild 2 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Outer Screen Connector: Schritt 8, Bild 3 von 3
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T Teardown, Remove Inner Screen Connector: Schritt 9, Bild 1 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Inner Screen Connector: Schritt 9, Bild 2 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Inner Screen Connector: Schritt 9, Bild 3 von 3
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T Teardown, Remove Motherboard: Schritt 10, Bild 1 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Motherboard: Schritt 10, Bild 2 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Motherboard: Schritt 10, Bild 3 von 3
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T Teardown, Remove Screen: Schritt 11, Bild 1 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Screen: Schritt 11, Bild 2 von 3 T-Mobile Huawei Prism U8651T Teardown, Remove Screen: Schritt 11, Bild 3 von 3
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
  12. T-Mobile Huawei Prism U8651T Teardown: Schritt 12, Bild 1 von 1
    • Teardown complete
Dillon
578 Reputation
5 Anleitungen geschrieben
Michigan Tech, Team 1-7, Lauer Fall 2014 Mitglied von Michigan Tech, Team 1-7, Lauer Fall 2014
MTU-LAUER-F14S1G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 2,342
