Zum Hauptinhalt wechseln
Brother PT-1010 Battery Replacement
  1. Brother PT-1010 Battery Replacement, Removing Back Panel: Schritt 1, Bild 1 von 1
    • Turn device so you are looking down at the top
  2. Brother PT-1010 Battery Replacement: Schritt 2, Bild 1 von 2 Brother PT-1010 Battery Replacement: Schritt 2, Bild 2 von 2
    • Press firmly on arrow indicator and pull panel toward you.
  3. Brother PT-1010 Battery Replacement, Remove Dead Batteries: Schritt 3, Bild 1 von 1
    • Remove dead batteries one at a time by pulling up on the side indicated with a + symbol.
    • Make sure the battery compartment is empty and clear of debris.
  4. Brother PT-1010 Battery Replacement: Schritt 4, Bild 1 von 2 Brother PT-1010 Battery Replacement: Schritt 4, Bild 2 von 2
    • Insert the first battery with the flat side (indicated by a - symbol on the battery) facing to the left of the battery compartment.
    • Do the same thing to insert the next 2 batteries.
  5. Brother PT-1010 Battery Replacement: Schritt 5, Bild 1 von 1
    • The next 3 batteries will be inserted on top of the others.
    • Insert the 4th battery with the flat side (indicated by the - symbol on the battery) facing to the right of the battery compartment.
  6. Brother PT-1010 Battery Replacement: Schritt 6, Bild 1 von 1
    • Repeat step 5 to insert the last 2 batteries.
  7. Brother PT-1010 Battery Replacement, Replace Back Panel: Schritt 7, Bild 1 von 1
    • Reinsert back panel.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Haley Sweet
460 Reputation
4 Anleitungen geschrieben
Baylor, Team 4-4, Williams Fall 2014 Mitglied von Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 4,813
