Zum Hauptinhalt wechseln
Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement
Was du brauchst
  1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Battery: Schritt 1, Bild 1 von 1
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 2, Bild 1 von 1
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 3, Bild 2 von 2
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 4, Bild 2 von 2
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Lower Case: Schritt 5, Bild 1 von 1
    • Unscrew all of the visible screws on the bottom of the laptop.
    • The screws circled are not necessary to remove.
    • Keeping track of which hole each screw goes in will speed up reassembly.
  6. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the screws located beneath the battery.
  7. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: Schritt 7, Bild 1 von 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: Schritt 7, Bild 2 von 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: Schritt 7, Bild 3 von 3
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  8. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the two screws near the top of the keyboard.
  9. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 9, Bild 2 von 2
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  10. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 10, Bild 1 von 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 10, Bild 2 von 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 10, Bild 3 von 3
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  11. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: Schritt 11, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: Schritt 11, Bild 2 von 2
    • Unscrew the screws on either side of the power button circuit board.
  12. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 12, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 12, Bild 2 von 2
    • Pull upward on the small white ribbon cable to detach from circuit board.
  13. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Optical Drive: Schritt 13, Bild 1 von 1
    • Unscrew the screw located on the left side of the optical drive near the heat sink cover in the middle of the laptop.
  14. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 14, Bild 1 von 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 14, Bild 2 von 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 14, Bild 3 von 3
    • Using spudger, push the optical drive out to the right.
  15. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: Schritt 15, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: Schritt 15, Bild 2 von 2
    • Disconnect both speaker connectors located near the center of the laptop.
  16. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 16, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 16, Bild 2 von 2
    • Unscrew all visible screws on the heat sink shield.
  17. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 17, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 17, Bild 2 von 2
    • Disconnect the monitor connector.
  18. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 18, Bild 1 von 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 18, Bild 2 von 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 18, Bild 3 von 3
    • Starting from the front right corner pry apart the black bottom from the gray top.
  19. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 19, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 19, Bild 2 von 2
    • Set aside the top half.
  20. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: Schritt 20, Bild 1 von 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: Schritt 20, Bild 2 von 2
    • Unscrew the remaining screws on the heatsink and fan brackets.
  21. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 21, Bild 1 von 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 21, Bild 2 von 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 21, Bild 3 von 3
    • Disconnect the fan power connector.
    • Remove the heatsink and fan.
    • Check the heatsink fins and fan for any dust build-up. If any is found use compressed air to clean.
  22. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: Schritt 22, Bild 1 von 1
    • Clean the old thermal paste off the CPU and heatsink.
    • Use a q tip to remove the majority of the thermal paste.
    • Use an isopropyl alcohol soaked q tip to further clean remaining thermal paste.
    • Dry and clean both surfaces with another q-tip.
    • Once completely clean, apply a rice grain sized amount of new thermal paste to the CPU and reattach the heatsink and fan.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kiril Lange
943 Reputation
9 Anleitungen geschrieben
USF Tampa, Team 3-2, Brown Fall 2014 Mitglied von USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 879
