Zum Hauptinhalt wechseln
Nintendo DSi XL Rear Bezel Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Nintendo DSi XL Rear Bezel Replacement, Battery: Schritt 1, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Rear Bezel Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Rear Bezel Replacement, Lower Case: Schritt 3, Bild 1 von 3 Nintendo DSi XL Rear Bezel Replacement, Lower Case: Schritt 3, Bild 2 von 3 Nintendo DSi XL Rear Bezel Replacement, Lower Case: Schritt 3, Bild 3 von 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Rear Bezel Replacement: Schritt 4, Bild 1 von 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Rear Bezel Replacement: Schritt 5, Bild 1 von 3 Nintendo DSi XL Rear Bezel Replacement: Schritt 5, Bild 2 von 3 Nintendo DSi XL Rear Bezel Replacement: Schritt 5, Bild 3 von 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Rear Bezel Replacement: Schritt 6, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 6, Bild 2 von 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Rear Bezel Replacement: Schritt 7, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 7, Bild 2 von 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Rear Bezel Replacement, Wi-Fi Board: Schritt 8, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement, Wi-Fi Board: Schritt 8, Bild 2 von 2
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Nintendo DSi XL Rear Bezel Replacement: Schritt 9, Bild 1 von 1
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
  10. Nintendo DSi XL Rear Bezel Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  11. Nintendo DSi XL Rear Bezel Replacement: Schritt 11, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 11, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  12. Nintendo DSi XL Rear Bezel Replacement: Schritt 12, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 12, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  13. Nintendo DSi XL Rear Bezel Replacement: Schritt 13, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 13, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  14. Nintendo DSi XL Rear Bezel Replacement: Schritt 14, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 14, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  15. Nintendo DSi XL Rear Bezel Replacement: Schritt 15, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 15, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  16. Nintendo DSi XL Rear Bezel Replacement: Schritt 16, Bild 1 von 1
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  17. Nintendo DSi XL Rear Bezel Replacement: Schritt 17, Bild 1 von 1
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  18. Nintendo DSi XL Rear Bezel Replacement: Schritt 18, Bild 1 von 1
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  19. Nintendo DSi XL Rear Bezel Replacement: Schritt 19, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 19, Bild 2 von 2
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  20. Nintendo DSi XL Rear Bezel Replacement: Schritt 20, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 20, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
  21. Nintendo DSi XL Rear Bezel Replacement, Lower Display Assembly: Schritt 21, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement, Lower Display Assembly: Schritt 21, Bild 2 von 2
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
  22. Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: Schritt 22, Bild 1 von 3 Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: Schritt 22, Bild 2 von 3 Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: Schritt 22, Bild 3 von 3
    • Turn the DSi XL over and open the display.
    • When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over.
    • Use a pushpin to remove the four plastic screw covers on the front bezel.
  23. Nintendo DSi XL Rear Bezel Replacement: Schritt 23, Bild 1 von 1
    • Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
  24. Nintendo DSi XL Rear Bezel Replacement: Schritt 24, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 24, Bild 2 von 2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  25. Nintendo DSi XL Rear Bezel Replacement: Schritt 25, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 25, Bild 2 von 2
    • Insert a spudger into the gap between the front and rear bezel.
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  26. Nintendo DSi XL Rear Bezel Replacement: Schritt 26, Bild 1 von 2 Nintendo DSi XL Rear Bezel Replacement: Schritt 26, Bild 2 von 2
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  27. Nintendo DSi XL Rear Bezel Replacement: Schritt 27, Bild 1 von 1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  28. Nintendo DSi XL Rear Bezel Replacement: Schritt 28, Bild 1 von 1
    • Using the flat end of a spudger, pry the rear camera off the rear bezel.
    • Remove the rear bezel.
Abschluss
Brett Hartt
127.870 Reputation
143 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.718 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 591
