Zum Hauptinhalt wechseln
Asus PadFone S Front Facing Camera Replacement
Was du brauchst
  1. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: Schritt 1, Bild 1 von 1
    • Place your thumb in the charging port and pry the back cover off of the phone.
  2. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: Schritt 2, Bild 1 von 2 Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: Schritt 2, Bild 2 von 2
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
  3. Asus PadFone S Front Facing Camera Replacement, Remove the Battery: Schritt 3, Bild 1 von 2 Asus PadFone S Front Facing Camera Replacement, Remove the Battery: Schritt 3, Bild 2 von 2
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
  4. Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: Schritt 4, Bild 1 von 3 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: Schritt 4, Bild 2 von 3 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: Schritt 4, Bild 3 von 3
    • Once the Battery has been successfully removed, move on to the step 2.
  5. Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: Schritt 5, Bild 1 von 2 Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: Schritt 5, Bild 2 von 2
    • Disconnect the marked strips from the logic board using the tweezers.
    • Applying too much force may damage the strips/connectors.
    • Remember to remove speaker connection located at the bottom left hand corner.
  6. Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: Schritt 6, Bild 1 von 2 Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: Schritt 6, Bild 2 von 2
    • Disconnect the other two strips that connect the logic board to the phone.
  7. Asus PadFone S Front Facing Camera Replacement, Remove The Camera: Schritt 7, Bild 1 von 2 Asus PadFone S Front Facing Camera Replacement, Remove The Camera: Schritt 7, Bild 2 von 2
    • Turn over the logic board to locate the front camera.
    • Grasp the sides of the camera with the tweezers and carefully remove the camera from the logic board.
    • Applying to much force will damage the connective strip.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,493
