Zum Hauptinhalt wechseln
Asus PadFone S Motherboard Replacement
Was du brauchst
  1. Asus PadFone S Motherboard Replacement, Remove the Back Panel: Schritt 1, Bild 1 von 1
    • Place your thumb in the charging port and pry the back cover off of the phone.
  2. Asus PadFone S Motherboard Replacement, Remove the Back Panel: Schritt 2, Bild 1 von 2 Asus PadFone S Motherboard Replacement, Remove the Back Panel: Schritt 2, Bild 2 von 2
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
  3. Asus PadFone S Motherboard Replacement, Remove the Battery: Schritt 3, Bild 1 von 2 Asus PadFone S Motherboard Replacement, Remove the Battery: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
  4. Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: Schritt 4, Bild 1 von 3 Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: Schritt 4, Bild 2 von 3 Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: Schritt 4, Bild 3 von 3
    • Disconnect all wires and bands from microphone, SIM card port and side bottons
  5. Asus PadFone S Motherboard Replacement, Remove the Logic Board: Schritt 5, Bild 1 von 3 Asus PadFone S Motherboard Replacement, Remove the Logic Board: Schritt 5, Bild 2 von 3 Asus PadFone S Motherboard Replacement, Remove the Logic Board: Schritt 5, Bild 3 von 3
    • Disconnect remaining band from the logic board
    • Lift the logic board out of the phone
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Greg Betsold
96 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
need schematic side button asus padfone s..please send via email kepkep.erwin@gmail.com.
thanks..
kepkep - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 18
Insgesamt: 3,590
