Zum Hauptinhalt wechseln
Asus PadFone S Rear Facing Camera Replacement
Was du brauchst
  1. Asus PadFone S Rear Facing Camera Replacement, Remove Back Cover: Schritt 1, Bild 1 von 2 Asus PadFone S Rear Facing Camera Replacement, Remove Back Cover: Schritt 1, Bild 2 von 2
    • Place your thumb in the charging port and pry the back cover off of the phone.
    • Separate cover all the way around the sides of the phone.
  2. Asus PadFone S Rear Facing Camera Replacement, Remove Back Panel: Schritt 2, Bild 1 von 2 Asus PadFone S Rear Facing Camera Replacement, Remove Back Panel: Schritt 2, Bild 2 von 2
    • Remove all the screws on the back panel using a T5 Torx screwdriver.
    • Lift the back panel off to reveal the logic board and battery.
  3. Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: Schritt 3, Bild 1 von 3 Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: Schritt 3, Bild 2 von 3 Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: Schritt 3, Bild 3 von 3
    • The back camera is located at the top left on the logic board.
    • Use tweezers to lift back camera strip from logic board.
    • Lift back camera out of logic board.
    • It is not necessary to remove logic board for removal of the back camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,338
