Einleitung
This guide will show you how to replace the motherboard, as yours may be malfunctioning. This is one of the longer processes so be patient. Tools are required. There are quite a few screws in this process so be sure to not lose any, and remember which ones came from where.
Was du brauchst
Slide the plastic case off of the back of the phone, exposing the battery.
Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
Using a prying tool, snap off the front casing on the top and bottom of the phone.
Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
Using tweezers, carefully disconnect the cable connector by pulling the cable out.
Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
