Zum Hauptinhalt wechseln
Samsung Galaxy Light Earpiece Speaker Replacement
Was du brauchst
  1. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Back Cover: Schritt 1, Bild 1 von 1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Battery: Schritt 2, Bild 1 von 1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Earpiece Speaker Replacement, Unscrew Midframe: Schritt 3, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Midframe: Schritt 4, Bild 1 von 1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: Schritt 5, Bild 1 von 3 Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: Schritt 5, Bild 2 von 3 Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: Schritt 5, Bild 3 von 3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: Schritt 6, Bild 1 von 2 Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool to pry up the headphone jack, vibrator, and earpiece speaker assembly.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Paul Goyette
475 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 686
