Zum Hauptinhalt wechseln
BLU Studio 5.0 S II Speaker Replacement
Was du brauchst
  1. BLU Studio 5.0 S II Speaker Replacement, Remove back cover.: Schritt 1, Bild 1 von 1
    • Remove the back cover on the phone with the plastic opening tool.
  2. BLU Studio 5.0 S II Speaker Replacement, Remove battery: Schritt 2, Bild 1 von 1
    • Remove battery with plastic opening tool.
  3. BLU Studio 5.0 S II Speaker Replacement, Remove screws: Schritt 3, Bild 1 von 1
    • On the bottom part of the back of the phone with a Phillips screwdriver #00 tool remove the 6 screws that hold the speaker in place.
  4. BLU Studio 5.0 S II Speaker Replacement, Remove speaker plastic backing: Schritt 4, Bild 1 von 1
    • After removing screws gently pull off the speaker from the back of the phone.
  5. BLU Studio 5.0 S II Speaker Replacement, Remove speaker.: Schritt 5, Bild 1 von 1
    • Remove the speaker from the backing of the speaker holder.
  6. BLU Studio 5.0 S II Speaker Replacement, Replace speaker.: Schritt 6, Bild 1 von 1
    • Replace the old speaker with a new speaker. Put it back in where the old speaker was.
  7. BLU Studio 5.0 S II Speaker Replacement, Put the screws back on: Schritt 7, Bild 1 von 1
    • Insert the plastic backing of the speaker back in the phone.
    • Put the six screws back in the backing of the phone to hold the plastic backing securely.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Maria Juzaino
499 Reputation
3 Anleitungen geschrieben
Gateway, Team 1-3, Johnson Fall 2014 Mitglied von Gateway, Team 1-3, Johnson Fall 2014
GCC-JOHNSON-F14S1G3
3 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Excellent instruction! Great pictures as well! Well done+!
Kelly - Antwort
Can you upload a guide on how to replace this device's screen? Pretty much appreciated.
Moe Ojeda - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 1,626
