Zum Hauptinhalt wechseln
MacBook Pro 17" Unibody Hard Drive Cable Replacement
Was du brauchst
  1. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Hard Drive Cable Replacement: Schritt 2, Bild 1 von 2 MacBook Pro 17" Unibody Hard Drive Cable Replacement: Schritt 2, Bild 2 von 2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: Schritt 3, Bild 1 von 3 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: Schritt 3, Bild 2 von 3 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: Schritt 3, Bild 3 von 3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. MacBook Pro 17" Unibody Hard Drive Cable Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard drive bracket from the upper case.
  6. MacBook Pro 17" Unibody Hard Drive Cable Replacement: Schritt 6, Bild 1 von 1
    • Use the hard drive's pull tab to lift it out of the upper case.
    • Don't try to completely remove the hard drive just yet! Its cable is still connected.
  7. MacBook Pro 17" Unibody Hard Drive Cable Replacement: Schritt 7, Bild 1 von 2 MacBook Pro 17" Unibody Hard Drive Cable Replacement: Schritt 7, Bild 2 von 2
    • Pull the hard drive connector away from the body of the hard drive.
    • Remove the hard drive from your MacBook Pro.
  8. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive Cable: Schritt 8, Bild 1 von 2 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive Cable: Schritt 8, Bild 2 von 2
    • Remove the following four screws securing the hard drive cable assembly to the upper case:
    • Two 1.6 mm Phillips screws securing the shield that covers the hard drive cable connector.
    • Two 2.2 mm Phillips screws securing the hard drive cable connector to the upper case.
    • Remove the shield from the logic board.
  9. MacBook Pro 17" Unibody Hard Drive Cable Replacement: Schritt 9, Bild 1 von 1
    • Use the flat end of a spudger to pry the hard drive connector up and out of its socket on the logic board.
  10. MacBook Pro 17" Unibody Hard Drive Cable Replacement: Schritt 10, Bild 1 von 1
    • Lift the hard drive cable out of the upper case.
Abschluss
16 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 21
Insgesamt: 20,223
