Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein iPod Shuffle 4th Generation zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. iPod Shuffle 4th Generation Teardown, iPod Shuffle 4th Generation Teardown: Schritt 1, Bild 1 von 2 iPod Shuffle 4th Generation Teardown, iPod Shuffle 4th Generation Teardown: Schritt 1, Bild 2 von 2
    • Apple's latest incarnation of the Shuffle bears little resemblance to its immediate predecessor.
    • Although the Shuffle features "new, smaller packaging," it doesn't feature a similarly resized shipping box. Apple could have shipped 30 iPod Shuffles in this box. Literally.
    • Its Apple model number is A1373, updated from the previous Shuffle's A1271 designation.
  2. iPod Shuffle 4th Generation Teardown: Schritt 2, Bild 1 von 2 iPod Shuffle 4th Generation Teardown: Schritt 2, Bild 2 von 2
    • The 4th Gen Shuffle is priced at a paltry $49.99! The original iPod shuffle cost $99, and had only 512 MB of storage.
    • There's a button just for VoiceOver: push once for artist and song, twice for battery status, and hold for playlist menu.
    • Apple admitted that people actually like buttons and brought them back for this generation.
    • Pshhh! Those of us with 3rd Gen Shuffles just printed out this convenient chart and carried it around for reference.
  3. iPod Shuffle 4th Generation Teardown: Schritt 3, Bild 1 von 2 iPod Shuffle 4th Generation Teardown: Schritt 3, Bild 2 von 2
    • Here's the full lineup.
    • There seems to be pattern here: skinny, fat, skinny, fat. It seems like Apple can't decide what shape they like best.
    • iPod Shuffle 4th Generation:
    • Height: 1.14"
    • Width: 1.24"
    • Depth: 0.34"
    • Weight: 0.44 oz.
    • A bank was robbed last week in Ba Sing Se. Witnesses were given this lineup to identify the perpetrator.
  4. iPod Shuffle 4th Generation Teardown: Schritt 4, Bild 1 von 2 iPod Shuffle 4th Generation Teardown: Schritt 4, Bild 2 von 2
    • Although this step makes it look super-simple to open the Shuffle, it's not. It took us a good half hour of prying and heat-gunning to open the little guy.
    • Pro tip: Aluminum gets hot when it's heated!
  5. iPod Shuffle 4th Generation Teardown: Schritt 5, Bild 1 von 1
    • The exposed internals.
    • The logic board is stuffed alongside the battery in the outer case.
    • Notice the glue residue along the edges of the opening.
    • Apple press-fit and glued the back clip onto the body. No wonder it was such a doozy to open!
  6. iPod Shuffle 4th Generation Teardown: Schritt 6, Bild 1 von 2 iPod Shuffle 4th Generation Teardown: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Even the seemingly simple task of disconnecting the control pad ribbon cable turns out to be quite a chore when the connector is 1/8" wide.
    • We have a feeling that as technology advances, we'll need smaller and smaller tools to take devices apart. You won't be able to see our hands in pictures, just little pointy tweezers.
    • We already have a microscope ready and waiting in the back room for when that time comes -- but we're not there quite yet (thankfully).
  7. iPod Shuffle 4th Generation Teardown: Schritt 7, Bild 1 von 3 iPod Shuffle 4th Generation Teardown: Schritt 7, Bild 2 von 3 iPod Shuffle 4th Generation Teardown: Schritt 7, Bild 3 von 3
    • Our huge #00 screwdriver makes short work of the logic board screw.
    • A plastic opening tool is needed to lift the battery off the light adhesive holding it to the case.
    • After the battery is out, a small plastic logic board retainer must be removed with none other than a dental pick.
  8. iPod Shuffle 4th Generation Teardown: Schritt 8, Bild 1 von 1
    • We remove the logic board and battery together from the iPod, because Apple once again chose to solder the battery to the logic board.
    • The loss of user-serviceability is the price we pay for small, sleek design.
  9. iPod Shuffle 4th Generation Teardown: Schritt 9, Bild 1 von 2 iPod Shuffle 4th Generation Teardown: Schritt 9, Bild 2 von 2
    • Removing the last four screws in the iPod Shuffle, which secure the control pad to the front of the iPod.
    • The button and control pads pop out together with a gentle push.
  10. iPod Shuffle 4th Generation Teardown: Schritt 10, Bild 1 von 1
    • The control pad comes out of the front case without any additional trouble.
  11. iPod Shuffle 4th Generation Teardown: Schritt 11, Bild 1 von 2 iPod Shuffle 4th Generation Teardown: Schritt 11, Bild 2 von 2
    • With a listed capacity of .19 Whr, this small 3.7V lithium-ion battery pumps out 15 hours of audio playback.
    • To calculate the capacity in amp-hours, we know P(power) = I(amps)*V(volts), so I = P/V. That yields a capacity of about .051 amp-hours, or 51 mAh. To say the least, that's diminutive in the world of batteries.
    • It's remarkable how long a battery lasts when it doesn't have to power a backlight.
  12. iPod Shuffle 4th Generation Teardown: Schritt 12, Bild 1 von 2 iPod Shuffle 4th Generation Teardown: Schritt 12, Bild 2 von 2
    • APPLE 338S0860 C0AN1021 TWN
    • 339S0128 / K9GA608U0E BC80 / FDEF26QV 1025 / 8443 ARM / N2N63MQ1 1031
    • Unsurprisingly, the date codes on this package indicate die manufacture dates in late June (1025) and early August 2010 (1031).
    • "K9GA6" indicates Samsung 16Gb flash, unlike the Nano and touch which use Toshiba flash.
  13. iPod Shuffle 4th Generation Teardown: Schritt 13, Bild 1 von 2 iPod Shuffle 4th Generation Teardown: Schritt 13, Bild 2 von 2
    • iPod Shuffle 4th Generation Repairability: 2 out of 10 (10 is easiest to repair)
    • Good: The control pad is attached to the logic board via a connector, allowing it to be easily separated.
    • Good: The lack of a screen eliminates a large weak point of other devices, making the Shuffle more resilient to falls. Just don't flush it down the toilet.
    • Bad: You essentially have to break it to open it.
    • Bad: The battery is soldered to the logic board, making replacement that much more difficult.
    • Bad: Apple keeps shrinking connectors. These super-small cable connectors are increasingly difficult to open without breaking them.
6 Kommentare
That guy stratched PCB, broke edge of a chip and totally wrench one capatitor. Seen on step 12. Thanks for HQ photos. I wish more patience to author, next time...
quido speedy - Antwort
Thank you very much. The guide is very good and I was able to change the battery of my ipod shuffle. It is working again.
Helena Matias - Antwort
Hey,
do you mind sharing where you got your battery .. and how much it cost .. ? I’m curious to see how stuff changed in 7 years.
Mine’s still doing ok (bought 2011, used extremely often), but … it’s showing its age.
Thanks ✌️
Darie H -
Btw, u don't need a spludge to open up the outer casing for step 4.
U just wedge the clip with something thin, and it creates a weak point on the casing so u get another person with a thin wedge to use that weak point to open it up.
Mark Hong - Antwort
How difficult is it to play any streaming media passing through ipod shuffle or ipod nano hardware
Ankit Anurag - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 65
Letzte 30 Tage: 273
Insgesamt: 258,428
