Einleitung
This LED strip gives your truck a more kickass appearance to complete the look. It's not every day that you see trucks with some pretty neat LED strip lights so be the first one on the road to have LED tailgate strip lamps! These are LED tail gate strip lights with 4 functions: on/off brake mode, left turn signal, right turn signal, and reverse mode. These LED strip lights are universal fit so you don't have to worry about compatibility issues.
Was du brauchst
Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp.
Use soap and water to scrub the area clean since that place is normally dirty.
Carefully measure beforehand where you're going to attach the LED strip so it looks even.
The LED tailgate strip is designed to be a little bit shorter than the trunk tailgate.
Straighten the LED strip and peel adhesive.
OPTIONAL: The package includes 4 mounting brackets with screws. You can use these to further secure the LED tailgate lights.
Tap reverse light wire.
You will need to remove either side of the tail light to locate the reverse light.
Use a T-tap to tap the reverse light wire from the tailgate LED strip to positive.
This is the trailer light connector. You can see: ground, brake, left signal, right signal - plug that into stock trailer light connector.
You will find the trailer light connector near the tow hitch.
Hide the wires or zip-tie them.
Check the trunk LED tailgate lamp to make sure everything works.
You're now on your way to being the coolest truck on the road with your new trunk LED tailgate strip lights!
5 weitere Nutzer:innen haben diese Anleitung absolviert.
21 Kommentare
Should my light bar come on with my headlights they worked without the headlights but when I turn headlights on they don't work what's wrong
did you get a answer to your problem because I'm having the same problem
Anyone have the answer to this problem yet?
Trevor G -
I bought a led third brake below the tailgate and i have five wires on the led light.what is the wiring diagram for it
