Zum Hauptinhalt wechseln
Kindle Fire HD 6 Rear Facing Camera Replacement
Was du brauchst
  1. Kindle Fire HD 6 Rear Facing Camera Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Rear Facing Camera Replacement: Schritt 2, Bild 1 von 2 Kindle Fire HD 6 Rear Facing Camera Replacement: Schritt 2, Bild 2 von 2
    • Carefully separate the back panel from the rest of the device internals.
  3. Kindle Fire HD 6 Rear Facing Camera Replacement, Rear Facing Camera: Schritt 3, Bild 1 von 1
    • Unscrew the two 3.5mm T5 Torx Screws from the top of the camera.
  4. Kindle Fire HD 6 Rear Facing Camera Replacement: Schritt 4, Bild 1 von 3 Kindle Fire HD 6 Rear Facing Camera Replacement: Schritt 4, Bild 2 von 3 Kindle Fire HD 6 Rear Facing Camera Replacement: Schritt 4, Bild 3 von 3
    • Be careful not to damage the camera lens as you remove the camera.
    • Gently pull the camera up and out of the device. As you pull, unclip the black and white connector with orange tape by popping it off at its base.
Abschluss
Cal Poly, Team 70-4, Forte Winter 2015 Mitglied von Cal Poly, Team 70-4, Forte Winter 2015
CPSU-FORTE-W15S70G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 884
