Zum Hauptinhalt wechseln
1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation
Was du brauchst
  1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: Schritt 1, Bild 1 von 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: Schritt 1, Bild 2 von 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: Schritt 1, Bild 3 von 3
    • Take the Philips screwdriver and remove two Philips head screws on both sides of the high mount brake lamp.
    • Be sure to store the two Philips screws in a safe place so they don't get lost.
  2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: Schritt 2, Bild 1 von 2 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: Schritt 2, Bild 2 von 2
    • Pull out the truck high mount brake/tail light housing.
    • We recommend you pull out the housing with both hands so you don't break the water tight seal.
    • If in the event that you happen you break it, you may have some water leak issues so you would have to fix the high mount brake/tail lamp housing with some glue.
  3. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: Schritt 3, Bild 1 von 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: Schritt 3, Bild 2 von 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: Schritt 3, Bild 3 von 3
    • Remove the stock bulbs from its socket.
  4. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: Schritt 4, Bild 1 von 1
    • Replace with the LED bulb.
    • Test your new LED truck high mount brake lamps to make sure everything works.
    • If the LED lights don't light up, check the polarity by flipping the bulbs 180 degrees.
  5. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: Schritt 5, Bild 1 von 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: Schritt 5, Bild 2 von 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: Schritt 5, Bild 3 von 3
    • Put back the light housing and screw in the two Philips screws.
Abschluss
Test and enjoy your new LED truck high mount brake/tail replacement lights.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric Wu
3.357 Reputation
23 Anleitungen geschrieben
2 Kommentare
The problem is there are no screws to remove.
richard - Antwort
there are no screws to remove on my 3rd light I can’t change the bulb
richard - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 50
Insgesamt: 6,018
