Zum Hauptinhalt wechseln
1998-2002 Honda Accord Distributor Cap Replacement
Was du brauchst
  1. 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: Schritt 1, Bild 1 von 3 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: Schritt 1, Bild 2 von 3 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: Schritt 1, Bild 3 von 3
    • Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
    • The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
    • Mark the order of the spark plug wires on the new distributor cap with a silver sharpie marker -- it will make reinstallation much easier.
  2. 1998-2002 Honda Accord Distributor Cap Replacement: Schritt 2, Bild 1 von 1
    • Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
    • It may be helpful to slightly twist the wires as you pull them.
  3. 1998-2002 Honda Accord Distributor Cap Replacement: Schritt 3, Bild 1 von 2 1998-2002 Honda Accord Distributor Cap Replacement: Schritt 3, Bild 2 von 2
    • Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
    • The position of the third bolt is not visible in the second picture.
  4. 1998-2002 Honda Accord Distributor Cap Replacement: Schritt 4, Bild 1 von 1
    • Pull the distributor cap away from the engine and set it aside.
  5. 1998-2002 Honda Accord Distributor Cap Replacement: Schritt 5, Bild 1 von 2 1998-2002 Honda Accord Distributor Cap Replacement: Schritt 5, Bild 2 von 2
    • Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
    • Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
I need to do this procedure. Have never done this in years. Next time I will change my wires, plugs and now my distributor cap.
Thurman - Antwort
Where can I find the part number?
lawendellr - Antwort
what about 6 cylinder
ssingam75 - Antwort
excellent, thanks for you aportation.
julio cesar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 134
Insgesamt: 68,380
