Zum Hauptinhalt wechseln
Samsung Galaxy Alpha Battery Replacement
  1. Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: Schritt 1, Bild 1 von 3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: Schritt 1, Bild 2 von 3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: Schritt 1, Bild 3 von 3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha Battery Replacement, Battery: Schritt 2, Bild 1 von 2 Samsung Galaxy Alpha Battery Replacement, Battery: Schritt 2, Bild 2 von 2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Jon Brausch
1.542 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 20-17, Maness Winter 2015 Mitglied von Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Not even a full picture of the battery agh! I need to know if I can use note 4 battery
Alex Andrei - Antwort
Please also make sure that replacing the battery with a cheap knock off will disable NFC since the antenna is glued to the battery.
vargabp0 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 39
Insgesamt: 4,940
