Einleitung
The battery, like most batteries, gives juice to the device. This guide will show you how to carefully remove it for troubleshooting purposes.
Was du brauchst
Insert a plastic opening tool between the plastic panel shown on the device.
Use the tool to pry the plastic away from the device.
Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Use a plastic card to pry the battery away from the device.
Gently un-clip the battery plug from the device and remove the battery.
29 weitere Nutzer:innen haben diese Anleitung absolviert.
15 Kommentare
Where to find a replacement battery for kindle voyage 3G please if any one knows
Any advance on where one can find a replacement battery for the Kindle Journal?
