Zum Hauptinhalt wechseln
Munchkinz Battery Replacement
Was du brauchst
  1. Munchkinz Battery Replacement, Opening Device: Schritt 1, Bild 1 von 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Battery Replacement, Pry Device Apart: Schritt 2, Bild 1 von 2 Munchkinz Battery Replacement, Pry Device Apart: Schritt 2, Bild 2 von 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Battery Replacement, Separated Device: Schritt 3, Bild 1 von 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Battery Replacement, Removing battery: Schritt 4, Bild 1 von 3 Munchkinz Battery Replacement, Removing battery: Schritt 4, Bild 2 von 3 Munchkinz Battery Replacement, Removing battery: Schritt 4, Bild 3 von 3
    • Use the wide plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  5. Munchkinz Battery Replacement, Remove battery completely: Schritt 5, Bild 1 von 1
    • Use the Soldering Iron to disconnect the each cable.
Abschluss
Hee Jin Cho
113 Reputation
1 Anleitung geschrieben
UW Tacoma, Team 3-6, Rose Winter 2015 Mitglied von UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 500
