Zum Hauptinhalt wechseln
HP Pavilion dv6000 Wireless Card Replacement
Was du brauchst
  1. HP Pavilion dv6000 Wireless Card Replacement, Wireless Card: Schritt 1, Bild 1 von 1
    • Lay the laptop on a flat surface, battery side up.
    • Remove the two screws securing the RAM shield to the lower case.
    • The screws will remain captive within the shield.
    • Lift and remove the RAM shield up from the lower case.
  2. HP Pavilion dv6000 Wireless Card Replacement: Schritt 2, Bild 1 von 2 HP Pavilion dv6000 Wireless Card Replacement: Schritt 2, Bild 2 von 2
    • Use a pair of tweezers to disconnect both antennas from their sockets on the wireless card.
    • Be careful to pull on the contacts and not the wires. The crimps used to hold them to the wires are delicate.
  3. HP Pavilion dv6000 Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 3.7 mm Phillips screws securing the wireless card to the motherboard.
    • Upon removing the Phillips screws that secures the wireless card to the motherboard, the wireless card board should pop up from its top side.
    • Grasp the wireless card and pull it straight out of its socket on the motherboard.
  4. HP Pavilion dv6000 Wireless Card Replacement: Schritt 4, Bild 1 von 1
    • Wireless card remains.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ben Hirsch
3.826 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 21-33, Regan Fall 2010 Mitglied von Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 21
Insgesamt: 26,683
