Zum Hauptinhalt wechseln
Gateway MD2614u Processor Replacement
Was du brauchst
  1. Gateway MD2614u Processor Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Processor Replacement: Schritt 2, Bild 1 von 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Processor Replacement: Schritt 3, Bild 1 von 1
    • Lift off the cover.
  4. Gateway MD2614u Processor Replacement, Fan: Schritt 4, Bild 1 von 1
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Processor Replacement: Schritt 5, Bild 1 von 1
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Processor Replacement: Schritt 6, Bild 1 von 1
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Processor Replacement: Schritt 7, Bild 1 von 1
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
  8. Gateway MD2614u Processor Replacement, Processor: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Kaufen
    • The CPU is located under the heat sink you just removed.
    • It is a green card on a white plastic surface. There is a black lock on one side of the plastic.
    • Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
    • If done correctly, the lock makes a clicking noise when unlocked.
  9. Gateway MD2614u Processor Replacement: Schritt 9, Bild 1 von 1
    • Place your fingers on opposite edges of the green card.
    • Carefully lift the CPU upward.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Toni Pipes
333 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-31, Regan Fall 2010 Mitglied von Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 27
Insgesamt: 7,170
