Zum Hauptinhalt wechseln
Kindle 7th Generation Back Panel Replacement
Was du brauchst
  1. Kindle 7th Generation Back Panel Replacement, Front Panel: Schritt 1, Bild 1 von 2 Kindle 7th Generation Back Panel Replacement, Front Panel: Schritt 1, Bild 2 von 2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Back Panel Replacement: Schritt 2, Bild 1 von 1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
  3. Kindle 7th Generation Back Panel Replacement, Back Panel: Schritt 3, Bild 1 von 2 Kindle 7th Generation Back Panel Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
  4. Kindle 7th Generation Back Panel Replacement: Schritt 4, Bild 1 von 1
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Abby Roulier
966 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 6-28, Amido Winter 2015 Mitglied von Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 45
Insgesamt: 4,829
