Zum Hauptinhalt wechseln
HP Pavilion dv5000 Fan Replacement
Was du brauchst
  1. HP Pavilion dv5000 Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Fan Replacement, RAM Cover: Schritt 2, Bild 1 von 3 HP Pavilion dv5000 Fan Replacement, RAM Cover: Schritt 2, Bild 2 von 3 HP Pavilion dv5000 Fan Replacement, RAM Cover: Schritt 2, Bild 3 von 3
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 Fan Replacement, RAM: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Release the RAM by pressing the metal heads of the RAM clips to the sides. Use tweezers and the spudger to spread the clips until they are completely off the RAM.
    • There are two RAM cards in this device.
  4. HP Pavilion dv5000 Fan Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 4, Bild 3 von 3
    • Remove the RAM.
  5. HP Pavilion dv5000 Fan Replacement: Schritt 5, Bild 1 von 1
    • As in step 3, press the clips on both sides to release the second RAM clip.
  6. HP Pavilion dv5000 Fan Replacement: Schritt 6, Bild 1 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 6, Bild 2 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 6, Bild 3 von 3
    • Remove the RAM.
  7. HP Pavilion dv5000 Fan Replacement, Wifi Card: Schritt 7, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement, Wifi Card: Schritt 7, Bild 2 von 2
    • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
  8. HP Pavilion dv5000 Fan Replacement: Schritt 8, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement: Schritt 8, Bild 2 von 2
    • Remove the two 6.0mm Phillips screws from the wifi card.
    • Remove the wifi card.
  9. HP Pavilion dv5000 Fan Replacement, Hard Drive: Schritt 9, Bild 1 von 1
    • Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
  10. HP Pavilion dv5000 Fan Replacement: Schritt 10, Bild 1 von 1
    • Remove the two screws securing the hard drive cover.
  11. HP Pavilion dv5000 Fan Replacement: Schritt 11, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement: Schritt 11, Bild 2 von 2
    • Remove the hard drive cover.
    • The hard drive is now accessible.
  12. HP Pavilion dv5000 Fan Replacement: Schritt 12, Bild 1 von 1
    • Remove the two 5.0mm screws securing the hard drive bracket.
  13. HP Pavilion dv5000 Fan Replacement: Schritt 13, Bild 1 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 13, Bild 2 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 13, Bild 3 von 3
    • Slide the hard drive to the right until the edge of the hard drive is flush with the computer frame.
    • Lift the hard drive out of the hard drive bay, left side first.
  14. HP Pavilion dv5000 Fan Replacement: Schritt 14, Bild 1 von 1
    • Remove the hard drive.
    • If you are replacing the hard drive, remove the four additional screws (two on each side) securing the metal shield to the hard drive. Then, remove the shield from the drive.
  15. HP Pavilion dv5000 Fan Replacement, Optical Drive: Schritt 15, Bild 1 von 1
    • Remove the 11.0mm screw securing the optical drive to the computer.
  16. HP Pavilion dv5000 Fan Replacement: Schritt 16, Bild 1 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 16, Bild 2 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 16, Bild 3 von 3
    • Locate the optical drive. The optical drive is located on the left side of the RAM bay.
    • Press the exposed edge of the optical drive gently with the spudger until the drive releases from the computer frame.
    • Pull the optical drive completely out of the computer frame.
  17. HP Pavilion dv5000 Fan Replacement, Keyboard: Schritt 17, Bild 1 von 1
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the three 6.0mm screws.
    • Remove the two 5.0mm screws.
    • Remove the 6.0mm screw in the middle of the battery compartment.
  18. HP Pavilion dv5000 Fan Replacement: Schritt 18, Bild 1 von 1
    • Turn the computer over and open the screen. This provides access to the screen hinges.
    • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
  19. HP Pavilion dv5000 Fan Replacement: Schritt 19, Bild 1 von 1
    • Be careful not to bend the keyboard switch cover too far when removing it.
  20. HP Pavilion dv5000 Fan Replacement: Schritt 20, Bild 1 von 1
    • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
  21. HP Pavilion dv5000 Fan Replacement: Schritt 21, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement: Schritt 21, Bild 2 von 2
    • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
    • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
  22. HP Pavilion dv5000 Fan Replacement: Schritt 22, Bild 1 von 1
    • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lay the keyboard face down.
    • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
  23. HP Pavilion dv5000 Fan Replacement: Schritt 23, Bild 1 von 1
    • Lift the keyboard off the keyboard frame.
  24. HP Pavilion dv5000 Fan Replacement, Screen: Schritt 24, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement, Screen: Schritt 24, Bild 2 von 2
    • Use the plastic prying tool to disconnect the screen cable from the system board.
  25. HP Pavilion dv5000 Fan Replacement: Schritt 25, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement: Schritt 25, Bild 2 von 2
    • Remove the four 7.0mm screws securing the screen to the computer.
  26. HP Pavilion dv5000 Fan Replacement: Schritt 26, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement: Schritt 26, Bild 2 von 2
    • Separate the screen from the computer frame by lifting the screen straight up.
    • Disconnect the PCI wires by pulling them free of the computer.
  27. HP Pavilion dv5000 Fan Replacement, Motherboard: Schritt 27, Bild 1 von 1
    • Flip the computer over to access the screws on the underside of the frame.
    • Remove the two 3.0mm screws.
    • Remove the 5.0mm screw.
  28. HP Pavilion dv5000 Fan Replacement: Schritt 28, Bild 1 von 1
    • Remove the eight 10mm screws.
  29. HP Pavilion dv5000 Fan Replacement: Schritt 29, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement: Schritt 29, Bild 2 von 2
    • Flip the computer over so the touchpad is accessible.
    • Disconnect the touchpad cable by pulling on it gently.
  30. HP Pavilion dv5000 Fan Replacement: Schritt 30, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement: Schritt 30, Bild 2 von 2
    • Remove the three 5.0mm screws in the silver panel.
    • Remove the seven 10.0mm screws.
  31. HP Pavilion dv5000 Fan Replacement: Schritt 31, Bild 1 von 1
    • Lift the top cover off of the rest of the computer frame.
  32. HP Pavilion dv5000 Fan Replacement: Schritt 32, Bild 1 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 32, Bild 2 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 32, Bild 3 von 3
    • Press gently on the textured front of the Express Card, then release it. It will pop out of the slot.
    • Remove the Express Card from the Express Card slot.
  33. HP Pavilion dv5000 Fan Replacement: Schritt 33, Bild 1 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 33, Bild 2 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 33, Bild 3 von 3
    • Remove the 6.0mm screw that secures the display hinge support to the computer frame.
    • Remove the display hinge support.
    • Disconnect the power connector cable.
  34. HP Pavilion dv5000 Fan Replacement: Schritt 34, Bild 1 von 1
    • Disconnect the USB audio cable and the modem cable.
  35. HP Pavilion dv5000 Fan Replacement: Schritt 35, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement: Schritt 35, Bild 2 von 2
    • Press gently on the front of the wireless card, then release it. It will pop out of the slot.
    • Remove the wireless card from the wireless card slot.
  36. HP Pavilion dv5000 Fan Replacement: Schritt 36, Bild 1 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 36, Bild 2 von 3 HP Pavilion dv5000 Fan Replacement: Schritt 36, Bild 3 von 3
    • Remove the 10.0mm screw.
    • Remove the two 6.0mm screws securing the Express Card bracket.
    • Remove the Express Card bracket
  37. HP Pavilion dv5000 Fan Replacement: Schritt 37, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement: Schritt 37, Bild 2 von 2
    • Lift the system board off the computer frame.
  38. HP Pavilion dv5000 Fan Replacement, Fan: Schritt 38, Bild 1 von 1
    • Remove the two 10.0 mm screws securing the fan on either side of the external monitor port.
  39. HP Pavilion dv5000 Fan Replacement: Schritt 39, Bild 1 von 1
    • Remove the four 10.0 mm screws.
    • Remove the two 3.0 mm screws.
  40. HP Pavilion dv5000 Fan Replacement: Schritt 40, Bild 1 von 2 HP Pavilion dv5000 Fan Replacement: Schritt 40, Bild 2 von 2
    • Remove the fan from the computer frame.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 21-34, Regan Fall 2010 Mitglied von Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Mitglieder
11 Anleitungen geschrieben
2 Kommentare
Kılavuzu hazırlayan arkadaşa çok teşekkür ediyorum gayet açıklayıcı ve güzel olmuş.
Thank you so much my friend that is perfect.
ycltrn - Antwort
Kindly add this on dv 4000 also
Radhakrishnan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 25,406
