Zum Hauptinhalt wechseln
1985-1988 Volvo 740 Tire Rotation
Was du brauchst
  1. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Front Wheels: Schritt 1, Bild 1 von 1
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  2. 1985-1988 Volvo 740 Tire Rotation: Schritt 2, Bild 1 von 1
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame of car.
    • Only necessary to jack the car until the wheels are just off the ground.
  3. 1985-1988 Volvo 740 Tire Rotation: Schritt 3, Bild 1 von 1
    • Place jack stand on frame of car and remove jack.
    • Do no work under car supported only by hydraulic jack, serious injury or death may occur.
  4. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Rear Wheels: Schritt 4, Bild 1 von 1
  5. 1985-1988 Volvo 740 Tire Rotation: Schritt 5, Bild 1 von 2 1985-1988 Volvo 740 Tire Rotation: Schritt 5, Bild 2 von 2
    • Place jack head underneath frame couple (pictured).
  6. 1985-1988 Volvo 740 Tire Rotation: Schritt 6, Bild 1 von 2 1985-1988 Volvo 740 Tire Rotation: Schritt 6, Bild 2 von 2
    • Do not work under car supported only by hydraulic jack, serious injury or death may result.
  7. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: Schritt 7, Bild 1 von 2 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: Schritt 7, Bild 2 von 2
    • Pry off the all four hub caps by placing a small flathead screwdriver between hubcap and rim pulling the screwdriver away from tire.
    • Pull hubcaps away from tires.
  8. 1985-1988 Volvo 740 Tire Rotation: Schritt 8, Bild 1 von 1
    • Loosen each of the five lug nuts on all tires by turning them counter-clockwise with a 19mm wrench.
  9. 1985-1988 Volvo 740 Tire Rotation: Schritt 9, Bild 1 von 1
    • Remove tires by pulling directly away from car exposing brake rotors.
  10. 1985-1988 Volvo 740 Tire Rotation: Schritt 10, Bild 1 von 1
    • Swap tires according to diagram.
  11. 1985-1988 Volvo 740 Tire Rotation: Schritt 11, Bild 1 von 1
    • Place tires on axels.
    • Hand tighten the lug nuts with narrow end of nut towards car.
    • Finish tightening the lug nuts with 19mm Torque Wrench to a torque of 63 lb*ft.
Abschluss
Cal Poly, Team 3-28, Regan Fall 2010 Mitglied von Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 2,614
