Zum Hauptinhalt wechseln
Toshiba Satellite A75-S226 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite A75-S226 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 Toshiba Satellite A75-S226 Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 Toshiba Satellite A75-S226 Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
    • It may be helpful to first pry at the rear of the hinge covers (not shown) to release them. Then Insert the plastic opening tool underneath the top panel's sides and then front edge.
  2. Toshiba Satellite A75-S226 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite A75-S226 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the top panel by popping the panel out the top left socket, then do the same with the right side.
  3. Toshiba Satellite A75-S226 Keyboard Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite A75-S226 Keyboard Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite A75-S226 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 3.67 mm screws from the top corners of the keyboard.
  4. Toshiba Satellite A75-S226 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Use fingers to lift up the keyboard from the top.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  5. Toshiba Satellite A75-S226 Keyboard Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite A75-S226 Keyboard Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite A75-S226 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the cable connecting the keyboard with the motherboard.
    • Be aware of the locking tabs on each side of the ribbon-cable connector—they slide back about 2mm to free the cable.
    • Lift up and remove the keyboard.
Abschluss
Cal Poly, Team 4-43, Amido Fall 2010 Mitglied von Cal Poly, Team 4-43, Amido Fall 2010
CPSU-AMIDO-F10S4G43
5 Mitglieder
39 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 13
Insgesamt: 4,262
