Zum Hauptinhalt wechseln
How to Install an HID Conversion Kit
Was du brauchst
  1. How to Install an HID Conversion Kit, Headlights: Schritt 1, Bild 1 von 2 How to Install an HID Conversion Kit, Headlights: Schritt 1, Bild 2 von 2
    • Open the hood.
    • Locate the back of the headlights and remove the bolts holding the headlight housing.
  2. How to Install an HID Conversion Kit: Schritt 2, Bild 1 von 1
    • Unplug the stock harness and remove the headlights.
  3. How to Install an HID Conversion Kit: Schritt 3, Bild 1 von 2 How to Install an HID Conversion Kit: Schritt 3, Bild 2 von 2
    • Remove battery negative terminal.
    • Remove headlight cover and remove factory halogen bulb.
  4. How to Install an HID Conversion Kit: Schritt 4, Bild 1 von 1
    • Take out the HID bulb from the plastic shell and remove the circular plastic piece.
    • Remember not to touch the HID bulb glass!
    • If you accidentally touch it, you can clean it with some rubbing alcohol.
  5. How to Install an HID Conversion Kit: Schritt 5, Bild 1 von 2 How to Install an HID Conversion Kit: Schritt 5, Bild 2 von 2
    • Screw in the HID bulb back into the headlight housing.
    • Connect the wires of the HID bulb to the ballast and then connect the HID ballast back to the stock harness.
  6. How to Install an HID Conversion Kit: Schritt 6, Bild 1 von 1
    • Before you mount the ballast, test the HID light to make sure it lights up.
    • If not, turn the adapter wire 180 degrees.
    • Mount the HID ballast with zip ties.
  7. How to Install an HID Conversion Kit: Schritt 7, Bild 1 von 3 How to Install an HID Conversion Kit: Schritt 7, Bild 2 von 3 How to Install an HID Conversion Kit: Schritt 7, Bild 3 von 3
    • Put everything (like the headlight housing) back.
    • Enjoy!
Abschluss
Enjoy your new HID Conversion Kit and upgraded headlights or fog lights.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric Wu
3.357 Reputation
23 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 120
Insgesamt: 16,292
