Zum Hauptinhalt wechseln
Nextbook 8 Battery Replacement
Was du brauchst
  1. Nextbook 8 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Nextbook 8 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Battery Replacement: Schritt 2, Bild 1 von 2 Nextbook 8 Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Battery Replacement: Schritt 3, Bild 1 von 2 Nextbook 8 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Battery Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Battery Replacement: Schritt 5, Bild 1 von 2 Nextbook 8 Battery Replacement: Schritt 5, Bild 2 von 2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
Abschluss
22 weitere Nutzer:innen haben diese Anleitung absolviert.
Dylan Wiese
1.853 Reputation
5 Anleitungen geschrieben
Colorado Springs, Team 5-1, Panko Spring 2015 Mitglied von Colorado Springs, Team 5-1, Panko Spring 2015
UCCS-PANKO-S15S5G1
3 Mitglieder
10 Anleitungen geschrieben
4 Kommentare
Very helpful and well made.
Quentin Freed - Antwort
Where can I buy the battery???
scruff67 - Antwort
Check Ebay. That's where I'm headed right now.
Tina Carey -
im having connection issues i cant find any wifi period
crusher309 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 34
Insgesamt: 42,178
