Zum Hauptinhalt wechseln
Samsung ATIV Book 9 Plus Battery Replacement
Was du brauchst
  1. Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Battery Replacement: Schritt 2, Bild 1 von 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Samsung ATIV Book 9 Plus Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Samsung ATIV Book 9 Plus Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • Unscrew the four 4.55 mm Phillips #000 screws on the edges of the battery.
  4. Samsung ATIV Book 9 Plus Battery Replacement: Schritt 4, Bild 1 von 2 Samsung ATIV Book 9 Plus Battery Replacement: Schritt 4, Bild 2 von 2
    • Lift to remove the battery from the laptop.
    • Place in the new battery to match the edges located on the laptop. Push on the top edge of the battery to secure it in place.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Baylor, Team 2-3, Grigsby Spring 2015 Mitglied von Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Mitglieder
4 Anleitungen geschrieben
4 Kommentare
Could you point to the RAM modules in the pictures please
rerof - Antwort
http://www.myfixguide.com/manual/samsung...
There are no RAM modules. They are welded in the mother board.
Best regards!
Raul Lacavex -
any updated amazon product?
amitshalem - Antwort
I just bought and installed this battery from Amazon: https://www.amazon.com/gp/product/B07NW7...
Mark Wolfman -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 12,622
