Zum Hauptinhalt wechseln
Disassembling Canon PowerShot SD850 IS Case Removal
Was du brauchst
  1. Disassembling Canon PowerShot SD850 IS Case Removal, Battery: Schritt 1, Bild 1 von 3 Disassembling Canon PowerShot SD850 IS Case Removal, Battery: Schritt 1, Bild 2 von 3 Disassembling Canon PowerShot SD850 IS Case Removal, Battery: Schritt 1, Bild 3 von 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 2, Bild 1 von 2 Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 2, Bild 2 von 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Disassembling Canon PowerShot SD850 IS Case Removal, Case: Schritt 3, Bild 1 von 2 Disassembling Canon PowerShot SD850 IS Case Removal, Case: Schritt 3, Bild 2 von 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 4, Bild 1 von 3 Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 4, Bild 2 von 3 Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 4, Bild 3 von 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 5, Bild 1 von 2 Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 5, Bild 2 von 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 6, Bild 1 von 2 Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 6, Bild 2 von 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 7, Bild 1 von 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Disassembling Canon PowerShot SD850 IS Case Removal: Schritt 8, Bild 1 von 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Peter Tran
225 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 20-7, Maness Fall 2010 Mitglied von Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Had to exchange a battery/SD card cover on an Ixus970IS. This guide very helpful showing the way due to similar layout of the Ixus and the PS850IS! Thanx a lot! :-)
KBK Copenhagen DK
Keld Baden-Kristensen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 23
Insgesamt: 4,231
