Zum Hauptinhalt wechseln
Canon PowerShot S100 Control Dial Assembly Replacement
Was du brauchst
  1. Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: Schritt 1, Bild 1 von 3 Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: Schritt 1, Bild 2 von 3 Canon PowerShot S100 Control Dial Assembly Replacement, Outer Case: Schritt 1, Bild 3 von 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Control Dial Assembly Replacement: Schritt 2, Bild 1 von 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Control Dial Assembly Replacement: Schritt 3, Bild 1 von 3 Canon PowerShot S100 Control Dial Assembly Replacement: Schritt 3, Bild 2 von 3 Canon PowerShot S100 Control Dial Assembly Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
  4. Canon PowerShot S100 Control Dial Assembly Replacement, Control Dial Assembly: Schritt 4, Bild 1 von 1
    • Turn the camera over so that the LCD screen is facing you.
    • Remove the screw (3.9mm, Phillips #00) that is attaching the thin metal frame to the camera.
    • Remove the 2 screws (3.1mm, Phillips #00) that are attaching the control dial panel to the camera.
  5. Canon PowerShot S100 Control Dial Assembly Replacement: Schritt 5, Bild 1 von 1
    Kaufen
    • Using the tweezers, detach the ribbon cable that is connected to the dial panel.
  6. Canon PowerShot S100 Control Dial Assembly Replacement: Schritt 6, Bild 1 von 2 Canon PowerShot S100 Control Dial Assembly Replacement: Schritt 6, Bild 2 von 2
    • Turn the camera over so that the lens is facing you.
    • Using the tweezers, gently lift the flap that is securing the ribbon cable to the motherboard.
    • Using the tweezers, remove the ribbon cable from its socket.
  7. Canon PowerShot S100 Control Dial Assembly Replacement: Schritt 7, Bild 1 von 1
    • Gently pull the control dial panel, and its attached ribbon cable, through the opening between the top panel and the camera body.
Abschluss
Ricky
958 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-4, Leahy Winter 2015 Mitglied von USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 Mitglieder
Ein Kommentar
I have Canon S100 and it was stuck. Can I send this camera to you to get it fixed and if so, what is your address and how much it will cost?
Yeluchuri Paparao - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 1,275
