Zum Hauptinhalt wechseln
Gateway 600YG2 System Fan Replacement
Was du brauchst
  1. Gateway 600YG2 System Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 System Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 System Fan Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Remove the 5 screws holding the keyboard in place.
  4. Gateway 600YG2 System Fan Replacement: Schritt 4, Bild 1 von 2 Gateway 600YG2 System Fan Replacement: Schritt 4, Bild 2 von 2
    • Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  5. Gateway 600YG2 System Fan Replacement, System Fan: Schritt 5, Bild 1 von 2 Gateway 600YG2 System Fan Replacement, System Fan: Schritt 5, Bild 2 von 2
    • Unscrew the four captive screws.
    • Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
Abschluss
Cal Poly, Team 20-10, Maness Fall 2010 Mitglied von Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 2,289
