Zum Hauptinhalt wechseln
RCA RCT6378W2 Battery Replacement
Was du brauchst
  1. RCA RCT6378W2 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 RCA RCT6378W2 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 RCA RCT6378W2 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the two 2.4 mm x 4 mm Phillips #00 screws from the bottom of the tablet.
  2. RCA RCT6378W2 Battery Replacement: Schritt 2, Bild 1 von 3 RCA RCT6378W2 Battery Replacement: Schritt 2, Bild 2 von 3 RCA RCT6378W2 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the back cover with a plastic opening tool, exposing the battery and motherboard.
  3. RCA RCT6378W2 Battery Replacement: Schritt 3, Bild 1 von 3 RCA RCT6378W2 Battery Replacement: Schritt 3, Bild 2 von 3 RCA RCT6378W2 Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the two black tape strips from the battery pack.
  4. RCA RCT6378W2 Battery Replacement: Schritt 4, Bild 1 von 3 RCA RCT6378W2 Battery Replacement: Schritt 4, Bild 2 von 3 RCA RCT6378W2 Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the battery pack by carefully prying the battery back from the front cover. Then, remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
  5. RCA RCT6378W2 Battery Replacement: Schritt 5, Bild 1 von 1
    • Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
  6. RCA RCT6378W2 Battery Replacement: Schritt 6, Bild 1 von 3 RCA RCT6378W2 Battery Replacement: Schritt 6, Bild 2 von 3 RCA RCT6378W2 Battery Replacement: Schritt 6, Bild 3 von 3
    • The new wires must be soldered back into place on the motherboard at the original location.
    • For tips on soldering techniques, see this Soldering Guide.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Justin
425 Reputation
2 Anleitungen geschrieben
Clemson, Team 14-4, Shirley Spring 2015 Mitglied von Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Mitglieder
15 Anleitungen geschrieben
7 Kommentare
Links on ordering replacement batteries
Great step by step instructions not for novices!
Robert Groffel - Antwort
i liked good job
Luis Orellana - Antwort
Can you give information about this battery?
What type of battery is it?
Is Applicable under the Dangerous Goods Regulations?
carlos - Antwort
where do i order the battery for RCT6378W2
Michael Giulian - Antwort
RCT6378W2 where can i get a replacement battery
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 26,919
