Zum Hauptinhalt wechseln
Disassembling IBM ThinkPad A30 Speakers
Was du brauchst
  1. Disassembling IBM ThinkPad A30 Speakers, Battery: Schritt 1, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers, Battery: Schritt 1, Bild 2 von 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Speakers, Upper Case: Schritt 2, Bild 1 von 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  3. Disassembling IBM ThinkPad A30 Speakers: Schritt 3, Bild 1 von 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  4. Disassembling IBM ThinkPad A30 Speakers: Schritt 4, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers: Schritt 4, Bild 2 von 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  5. Disassembling IBM ThinkPad A30 Speakers: Schritt 5, Bild 1 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 5, Bild 2 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 5, Bild 3 von 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  6. Disassembling IBM ThinkPad A30 Speakers: Schritt 6, Bild 1 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 6, Bild 2 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 6, Bild 3 von 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  7. Disassembling IBM ThinkPad A30 Speakers: Schritt 7, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers: Schritt 7, Bild 2 von 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  8. Disassembling IBM ThinkPad A30 Speakers: Schritt 8, Bild 1 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 8, Bild 2 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 8, Bild 3 von 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
  9. Disassembling IBM ThinkPad A30 Speakers, Display Assembly: Schritt 9, Bild 1 von 1
    • Remove the 5.6mm screw that holds the LCD to the upper case.
  10. Disassembling IBM ThinkPad A30 Speakers: Schritt 10, Bild 1 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 10, Bild 2 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 10, Bild 3 von 3
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
  11. Disassembling IBM ThinkPad A30 Speakers: Schritt 11, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers: Schritt 11, Bild 2 von 2
    • Pull out the white tab connecting the LCD to the motherboard.
  12. Disassembling IBM ThinkPad A30 Speakers: Schritt 12, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers: Schritt 12, Bild 2 von 2
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
  13. Disassembling IBM ThinkPad A30 Speakers: Schritt 13, Bild 1 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 13, Bild 2 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 13, Bild 3 von 3
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
  14. Disassembling IBM ThinkPad A30 Speakers, Fan: Schritt 14, Bild 1 von 1
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
  15. Disassembling IBM ThinkPad A30 Speakers: Schritt 15, Bild 1 von 1
    • Lift the heatsink bracket up.
  16. Disassembling IBM ThinkPad A30 Speakers: Schritt 16, Bild 1 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 16, Bild 2 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 16, Bild 3 von 3
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
  17. Disassembling IBM ThinkPad A30 Speakers, Speakers: Schritt 17, Bild 1 von 1
    • Locate the floppy drive bay.
    • Remove the four 5.6mm screws.
    • Remove the 16mm screw.
  18. Disassembling IBM ThinkPad A30 Speakers: Schritt 18, Bild 1 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 18, Bild 2 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 18, Bild 3 von 3
    • Turn the laptop over so the battery is facing you.
    • Locate the modem and ethernet card bay.
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
  19. Disassembling IBM ThinkPad A30 Speakers: Schritt 19, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers: Schritt 19, Bild 2 von 2
    • Remove the four 9.1mm screws attached to the modem and ethernet cards.
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
  20. Disassembling IBM ThinkPad A30 Speakers: Schritt 20, Bild 1 von 1
    • Locate the hard drive slot.
    • Remove the 8.8mm screw with a Phillips #0 screwdriver.
  21. Disassembling IBM ThinkPad A30 Speakers: Schritt 21, Bild 1 von 1
    • Turn the laptop over again and orient it as shown.
    • Lift the left side of the floppy disk bay and and pull it out.
    • The black lever will pop out.
  22. Disassembling IBM ThinkPad A30 Speakers: Schritt 22, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers: Schritt 22, Bild 2 von 2
    • Locate the CD Drive Bay
    • Remove the three 5.6mm screws.
    • Lift the right side and pull the CD drive bay out.
  23. Disassembling IBM ThinkPad A30 Speakers: Schritt 23, Bild 1 von 1
    • Locate the speakers on the bottom left and right of the ThinkPad A30.
  24. Disassembling IBM ThinkPad A30 Speakers: Schritt 24, Bild 1 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 24, Bild 2 von 3 Disassembling IBM ThinkPad A30 Speakers: Schritt 24, Bild 3 von 3
    • Remove the 5.6mm screws on each speaker.
    • Pull the right speaker out, making sure there is still slack in the wire.
  25. Disassembling IBM ThinkPad A30 Speakers: Schritt 25, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers: Schritt 25, Bild 2 von 2
    • Pull the blue tab that holds the speaker chip and pull the chip out.
  26. Disassembling IBM ThinkPad A30 Speakers: Schritt 26, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers: Schritt 26, Bild 2 von 2
    • Remove the wires from the white tabs by lifting the black wire casing.
  27. Disassembling IBM ThinkPad A30 Speakers: Schritt 27, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers: Schritt 27, Bild 2 von 2
    • Lift the left speaker out.
  28. Disassembling IBM ThinkPad A30 Speakers: Schritt 28, Bild 1 von 2 Disassembling IBM ThinkPad A30 Speakers: Schritt 28, Bild 2 von 2
    • Remove the speaker data and power cables by pulling them from the motherboard.
    • You have successfully removed the ThinkPad A30 speakers.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alan
380 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 4-44, Amido Fall 2010 Mitglied von Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Mitglieder
26 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 2,096
