Einleitung
A step-by-step guide that illustrates the necessary precautions for replacing a battery for the Acer Iconia A100 tablet.
Was du brauchst
Start at any side of the tablet.
Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
Work your way around the tablet.
Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
Carefully separate the back piece from the device using a plastic opening tool.
Turn the tablet over so that the battery is facing upwards.
Remove the four 4mm screws located around the battery.
Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
