Einleitung
Before replacing your fan's motor, use this Comfort Zone CZ6C Fan Blades Replacement Guide.
Was du brauchst
Unscrew the main housing screw located right above the main switch using a Phillips screwdriver.
Then use gentle force to remove the main housing door.
Unscrew the two adjacent housing screws to free the motor cage from the housing.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
