Zum Hauptinhalt wechseln
Panasonic KX-E603 Case Replacement
Was du brauchst
  1. Panasonic KX-E603 Case Replacement, Case: Schritt 1, Bild 1 von 2 Panasonic KX-E603 Case Replacement, Case: Schritt 1, Bild 2 von 2
    • Flip the typewriter to expose the bottom body panel.
    • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
  2. Panasonic KX-E603 Case Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
  3. Panasonic KX-E603 Case Replacement: Schritt 3, Bild 1 von 1
    • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
  4. Panasonic KX-E603 Case Replacement: Schritt 4, Bild 1 von 2 Panasonic KX-E603 Case Replacement: Schritt 4, Bild 2 von 2
    • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
    • Remove the two 19 mm screws using a Phillips #2 screwdriver.
  5. Panasonic KX-E603 Case Replacement: Schritt 5, Bild 1 von 2 Panasonic KX-E603 Case Replacement: Schritt 5, Bild 2 von 2
    • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
  6. Panasonic KX-E603 Case Replacement: Schritt 6, Bild 1 von 3 Panasonic KX-E603 Case Replacement: Schritt 6, Bild 2 von 3 Panasonic KX-E603 Case Replacement: Schritt 6, Bild 3 von 3
    • Remove the roller wheel adjustment knobs by pulling firmly outward.
    • Both black knobs must be removed in this step.
  7. Panasonic KX-E603 Case Replacement: Schritt 7, Bild 1 von 2 Panasonic KX-E603 Case Replacement: Schritt 7, Bild 2 von 2
    • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
  8. Panasonic KX-E603 Case Replacement: Schritt 8, Bild 1 von 2 Panasonic KX-E603 Case Replacement: Schritt 8, Bild 2 von 2
    • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
  9. Panasonic KX-E603 Case Replacement: Schritt 9, Bild 1 von 3 Panasonic KX-E603 Case Replacement: Schritt 9, Bild 2 von 3 Panasonic KX-E603 Case Replacement: Schritt 9, Bild 3 von 3
    • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 17-1, Forte Spring 2015 Mitglied von Cal Poly, Team 17-1, Forte Spring 2015
CPSU-FORTE-S15S17G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 371
