Desktop PC Front Fan Replacement
  1. Desktop PC Front Fan Replacement, Left Panel: step 1, image 1 of 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Front Fan Replacement: step 2, image 1 of 2 Desktop PC Front Fan Replacement: step 2, image 2 of 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Front Fan Replacement, Front Fan: step 3, image 1 of 2 Desktop PC Front Fan Replacement, Front Fan: step 3, image 2 of 2
    • Push to unlatch three grey connectors on the front panel.
  4. Desktop PC Front Fan Replacement: step 4, image 1 of 1
    • Disconnect the front panel from the computer face.
  5. Desktop PC Front Fan Replacement: step 5, image 1 of 1
    • Remove four Phillips #2 head, 5mm screws holding in the fan.
  6. Desktop PC Front Fan Replacement: step 6, image 1 of 1
    • Slide the fan out from the side of the casing.
  7. Desktop PC Front Fan Replacement: step 7, image 1 of 1
    • Disconnect the power cable from the fan.
38 other people completed this guide.
David Lennon
9,944 Reputation
10 Guides authored
Cal Poly, Team 4-5, Maness Spring 2015 Member of Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Members
45 Guides authored
One Comment
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - Reply
Past 24 Hours: 10
Past 7 Days: 47
Past 30 Days: 148
All Time: 27,309
