Zum Hauptinhalt wechseln
Toilet Flapper Replacement
  1. Toilet Flapper Replacement, Tank Lid: Schritt 1, Bild 1 von 3 Toilet Flapper Replacement, Tank Lid: Schritt 1, Bild 2 von 3 Toilet Flapper Replacement, Tank Lid: Schritt 1, Bild 3 von 3
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: Schritt 2, Bild 1 von 2 Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: Schritt 2, Bild 2 von 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Flapper Replacement, Draining a Toilet Tank: Schritt 3, Bild 1 von 2 Toilet Flapper Replacement, Draining a Toilet Tank: Schritt 3, Bild 2 von 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: Schritt 4, Bild 1 von 3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: Schritt 4, Bild 2 von 3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: Schritt 4, Bild 3 von 3
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
  5. Toilet Flapper Replacement, Flapper: Schritt 5, Bild 1 von 3 Toilet Flapper Replacement, Flapper: Schritt 5, Bild 2 von 3 Toilet Flapper Replacement, Flapper: Schritt 5, Bild 3 von 3
    • Disconnect the flapper from the posts on each side of the overflow tube.
    • Remove the flapper from the toilet tank.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Kristen Gismondi
81.663 Reputation
200 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.732 Anleitungen geschrieben
2 Kommentare
Thank you I needed that
My Mama - Antwort
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 55
Letzte 30 Tage: 214
Insgesamt: 12,170
