Einleitung
This guide is used as a prereq to other guides.
Was du brauchst
Use the flat end of a spudger or your fingers to disconnect the following cables:
Speaker cable
Microphone cable
Fan cable
Power cable
Display data cable
Remove the 2.5 mm Phillips screw securing the power switch lever to the lower case.
Use a pair of tweezers or your fingers to lift the power switch lever out of the Mini 1000.
Remove the 2.5 mm Phillips screw securing the wireless on/off switch lever to the lower case.
Use tweezers or your fingers to remove the wireless on/off switch lever from the Mini 1000.
Remove the two 3 mm Phillips screws securing the USB bracket to the lower case.
Pry up the USB bracket and remove it from the motherboard.
Remove the single 4.5 mm Phillips screw securing the motherboard to the lower case near the fan.
Carefully lift the motherboard from its right edge and remove it from the lower case, minding any cables that may get caught.
