Zum Hauptinhalt wechseln
Disassembling Olympus Stylus 1010 Case
Was du brauchst
  1. Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: Schritt 1, Bild 1 von 2 Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: Schritt 1, Bild 2 von 2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Disassembling Olympus Stylus 1010 Case: Schritt 2, Bild 1 von 1
    • Remove the right side panel by pulling off the large silver piece.
  3. Disassembling Olympus Stylus 1010 Case: Schritt 3, Bild 1 von 2 Disassembling Olympus Stylus 1010 Case: Schritt 3, Bild 2 von 2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Disassembling Olympus Stylus 1010 Case: Schritt 4, Bild 1 von 1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Disassembling Olympus Stylus 1010 Case: Schritt 5, Bild 1 von 1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Disassembling Olympus Stylus 1010 Case: Schritt 6, Bild 1 von 3 Disassembling Olympus Stylus 1010 Case: Schritt 6, Bild 2 von 3 Disassembling Olympus Stylus 1010 Case: Schritt 6, Bild 3 von 3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Disassembling Olympus Stylus 1010 Case: Schritt 7, Bild 1 von 3 Disassembling Olympus Stylus 1010 Case: Schritt 7, Bild 2 von 3 Disassembling Olympus Stylus 1010 Case: Schritt 7, Bild 3 von 3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Max McIntyre
526 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 13-4, Forte Winter 2011 Mitglied von Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
How did you get the ring around the lens off?? I can't seem to find that step and in all the pictures it's already off
Maureen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 19
Insgesamt: 3,033
