Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Xbox One Wireless Controller 1697 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Xbox One Wireless Controller 1697 Teardown, XBOX One Wireless Controller: Schritt 1, Bild 1 von 2 Xbox One Wireless Controller 1697 Teardown, XBOX One Wireless Controller: Schritt 1, Bild 2 von 2
    • Covert Forces model - Bowie 'Changes' look.
    • New 3.5mm jack socket next to expansion port.
  2. Xbox One Wireless Controller 1697 Teardown, Remove plastics: Schritt 2, Bild 1 von 3 Xbox One Wireless Controller 1697 Teardown, Remove plastics: Schritt 2, Bild 2 von 3 Xbox One Wireless Controller 1697 Teardown, Remove plastics: Schritt 2, Bild 3 von 3
    • Remove battery cover and battery
    • Remove side panels using spudger
    • Expose T9 security screw under label
    • Remove 5 x T9 security screws from chassis
    • Remove top and bottom covers
  3. Xbox One Wireless Controller 1697 Teardown, Tape down rumble motors: Schritt 3, Bild 1 von 2 Xbox One Wireless Controller 1697 Teardown, Tape down rumble motors: Schritt 3, Bild 2 von 2
    • Tape down the rumbler motors to prevent them from falling out.
  4. Xbox One Wireless Controller 1697 Teardown, Seperate PCB's: Schritt 4, Bild 1 von 2 Xbox One Wireless Controller 1697 Teardown, Seperate PCB's: Schritt 4, Bild 2 von 2
    • Remove 2 x T6 security screws on bottom PCB
    • De-solder rumble pack and trigger wiring
  5. Xbox One Wireless Controller 1697 Teardown, CODEC and Jack Socket: Schritt 5, Bild 1 von 2 Xbox One Wireless Controller 1697 Teardown, CODEC and Jack Socket: Schritt 5, Bild 2 von 2
    • Thar she blows! DA7212
    • Dialog Semiconductor CODEC with Class G HP AMP and Class AB speaker driver.
    • CODEC sits next to contact pads for 3.5mm jack socket
Bito Zapata
158 Reputation
1 Anleitung geschrieben
15 Kommentare
Is it possible to show the other board? Was thinking of doing a scuf-style mod to one of these... Thanks
blazeclarkebcc - Antwort
Was asking this because the boards are different to the older controller. I have PCB prints of the old one, but not the new one. Thanks.
blazeclarkebcc -
Can you point me where to get schematics that you have?
Piotr Zieliński -
Anybody know where I can get the new style bumpers for this style of controller? Any help would be greatly appreciated.
Rhys Jones - Antwort
The guy I buy from on ebay said they would be available at the end of January
themadmaxof07 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 78
Letzte 30 Tage: 322
Insgesamt: 70,653
