Zum Hauptinhalt wechseln
Fujitsu LifeBook N3510 Keyboard Replacement
Was du brauchst
  1. Fujitsu LifeBook N3510 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Keyboard Replacement, Hinge Cover: Schritt 3, Bild 1 von 3 Fujitsu LifeBook N3510 Keyboard Replacement, Hinge Cover: Schritt 3, Bild 2 von 3 Fujitsu LifeBook N3510 Keyboard Replacement, Hinge Cover: Schritt 3, Bild 3 von 3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 5, Bild 1 von 3 Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 5, Bild 2 von 3 Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 6, Bild 1 von 2 Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 7, Bild 1 von 2 Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Keyboard Replacement, Keyboard: Schritt 8, Bild 1 von 3 Fujitsu LifeBook N3510 Keyboard Replacement, Keyboard: Schritt 8, Bild 2 von 3 Fujitsu LifeBook N3510 Keyboard Replacement, Keyboard: Schritt 8, Bild 3 von 3
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 9, Bild 1 von 2 Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 10, Bild 1 von 2 Fujitsu LifeBook N3510 Keyboard Replacement: Schritt 10, Bild 2 von 2
    • After the ribbon has been detached, carefully remove the keyboard.
Abschluss
Neil Daniels
1.411 Reputation
11 Anleitungen geschrieben
Cal Poly, Team 5-18, Amido Winter 2011 Mitglied von Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 26
Insgesamt: 5,988
