Zum Hauptinhalt wechseln
1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement
Was du brauchst
  1. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: Schritt 1, Bild 1 von 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: Schritt 1, Bild 2 von 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: Schritt 1, Bild 3 von 3
    • Here is the Jeep GC. Removal of the headlamp is identical for both sides.
    • By opening the hood and looking straight down on the headlamp assembly, the 6mm hex head jack screw can be seen.
    • Use a 6mm socket and nut driver to remove the jack screw. 1/4 socket will not fit 9/32 does, but it is a bit sloppy
  2. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: Schritt 2, Bild 1 von 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: Schritt 2, Bild 2 von 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: Schritt 2, Bild 3 von 3
    • Remove the long jack screw.
    • Grasp upper inboard and lower outboard corners of headlamp and forcefully pull headlamp outward.
    • Remove all bulb sockets from headlamp module. Separate headlamp from vehicle.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
oldturkey03
784.117 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
556 Anleitungen geschrieben
4 Kommentare
It’s a 7mm socket
Don Marcos - Antwort
Not on mine. Just rechecked and it is a 6mm on my Jeep
oldturkey03 -
Thankful for simple instructions without any extra info or words ?
robinrogersk9 - Antwort
I’m removing it to replace fan cooling module. I heard I can cut through to get to it without disassembling the grill bumper etc
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 47
Insgesamt: 7,583
