Zum Hauptinhalt wechseln
Sharp Aquos LC13B2UA Front Case Replacement
Was du brauchst
  1. Sharp Aquos LC13B2UA Front Case Replacement, Stand: Schritt 1, Bild 1 von 2 Sharp Aquos LC13B2UA Front Case Replacement, Stand: Schritt 1, Bild 2 von 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Front Case Replacement: Schritt 2, Bild 1 von 2 Sharp Aquos LC13B2UA Front Case Replacement: Schritt 2, Bild 2 von 2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Front Case Replacement, Back Case: Schritt 3, Bild 1 von 3 Sharp Aquos LC13B2UA Front Case Replacement, Back Case: Schritt 3, Bild 2 von 3 Sharp Aquos LC13B2UA Front Case Replacement, Back Case: Schritt 3, Bild 3 von 3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Front Case Replacement: Schritt 4, Bild 1 von 2 Sharp Aquos LC13B2UA Front Case Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Front Case Replacement: Schritt 5, Bild 1 von 1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Front Case Replacement, Motherboard: Schritt 6, Bild 1 von 3 Sharp Aquos LC13B2UA Front Case Replacement, Motherboard: Schritt 6, Bild 2 von 3 Sharp Aquos LC13B2UA Front Case Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Front Case Replacement: Schritt 7, Bild 1 von 2 Sharp Aquos LC13B2UA Front Case Replacement: Schritt 7, Bild 2 von 2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Front Case Replacement: Schritt 8, Bild 1 von 2 Sharp Aquos LC13B2UA Front Case Replacement: Schritt 8, Bild 2 von 2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Front Case Replacement: Schritt 9, Bild 1 von 1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  10. Sharp Aquos LC13B2UA Front Case Replacement, Power Button: Schritt 10, Bild 1 von 3 Sharp Aquos LC13B2UA Front Case Replacement, Power Button: Schritt 10, Bild 2 von 3 Sharp Aquos LC13B2UA Front Case Replacement, Power Button: Schritt 10, Bild 3 von 3
    • Remove the two 6mm Phillips screws.
    • Pull the board toward you, giving you access to the power button.
  11. Sharp Aquos LC13B2UA Front Case Replacement, Top Buttons: Schritt 11, Bild 1 von 2 Sharp Aquos LC13B2UA Front Case Replacement, Top Buttons: Schritt 11, Bild 2 von 2
    • Unscrew the two 4mm Phillips screws.
    • Lift the buttons off the front case.
  12. Sharp Aquos LC13B2UA Front Case Replacement, Front Case: Schritt 12, Bild 1 von 2 Sharp Aquos LC13B2UA Front Case Replacement, Front Case: Schritt 12, Bild 2 von 2
    • Remove the eight 10mm screws connecting the two speakers to the front case.
  13. Sharp Aquos LC13B2UA Front Case Replacement: Schritt 13, Bild 1 von 3 Sharp Aquos LC13B2UA Front Case Replacement: Schritt 13, Bild 2 von 3 Sharp Aquos LC13B2UA Front Case Replacement: Schritt 13, Bild 3 von 3
    • Remove the two black tape strips securing the audio cables to the case.
    • Lift the audio cable from the plastic prongs securing it to the front case
    • The speakers can now be removed.
  14. Sharp Aquos LC13B2UA Front Case Replacement: Schritt 14, Bild 1 von 3 Sharp Aquos LC13B2UA Front Case Replacement: Schritt 14, Bild 2 von 3 Sharp Aquos LC13B2UA Front Case Replacement: Schritt 14, Bild 3 von 3
    • To remove the LED circuit at the base of the front casing, unscrew the two 5mm Phillips screws.
    • Lift the circuit to remove the plastic LED casing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Robert Hobson
1.290 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 1-11, Amido Winter 2011 Mitglied von Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 12
Insgesamt: 2,790
