Einleitung
If your home button is smashed in, or isn't functioning properly then this guide will show you step-by-step instructions for home button replacement. This is very easy rated at 3 out of 10. and should only take 5 minutes.
Was du brauchst
Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
Using the plastic opening tool, pull up on the flex connector. It will come off the motherboard, but will stay attached to the cover like a hinge.
Place the plastic opening tool underneath the motherboard at this location. Gently pry the motherboard away from the front cover. It should pop off and be free from the cover.
Using the plastic opening tool, pry the home button away from the front cover.
The whole home button mechanism should lift right out.
