Zum Hauptinhalt wechseln
Samsung Galaxy Tab 4 7.0 Battery Replacement
Was du brauchst
Einführungsvideo
  1. Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Battery Replacement: Schritt 2, Bild 1 von 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
Abschluss
28 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 1-3, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Mitglieder
12 Anleitungen geschrieben
3 Kommentare
This is for a cell phone, not a tablet. Why?
ckmjunk - Antwort
it is the tablet
sourcandysaiyan -
OH! its so easy!! woohoo, ordering battery now!
sourcandysaiyan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 44
Insgesamt: 26,578
